You can back up data in either of the following ways:
Note: For a distributed configuration, the Enterprise Overview data and NFA console configuration data are on the NFA console server. The other databases that are discussed here are on the Harvester server. For a standalone system, all the databases are on the standalone server.
A confirmation message opens, which identifies the dependent services that will also stop.
The confirmation message closes and the services stop.
Note: On a Linux server that has a Harvester installed, stop the following services:
If you do not have enough space for all of the files, you can limit the backup to include only particular tables. Remember that the other collected data is not backed up, however.
Note: The database paths are the same on Windows servers and Linux servers.
To back up poller data, see Back Up the Poller Database.
You can back up Poller data in either of the following ways:
Poller data contains information about devices and interfaces, which is retrieved through polling.
Note: The database path is the same for a Windows server or Linux server.
Note: On a Linux server that has a Harvester installed, stop the following nfa_poller service.
