Previous Topic: Capture Card Clock Differs from System ClockNext Topic: Time Range Exceeds Raw Packet Retention Time
CA TIM is Not Configured to Use Napatech
Symptom:
I see the following message in the CA TIM error log:
Napatech software is installed but TIM is not configured to use Napatech.
Solution:
This message appears when CA TIM is installed on the Multi-Port Monitor appliance. Because Multi-Port Monitor is configured to manage the Napatech card, you can safely ignore this message.
