Previous Topic: CA TIM is Not Configured to Use NapatechNext Topic: Best Practices for Deployment
Time Range Exceeds Raw Packet Retention Time
Symptom:
I received the following warning message when attempting to export data to PCAP format:
Time range exceeds raw packet capture retention time.
Solution:
The Applications Settings page in the web interface includes a File Retention setting that affects the Export to PCAP feature. The error occurs when the data you want to export is from a time frame that is less than the "Keep raw packet capture files for" setting.
Use the System Status page to assess the disk usage for data in the File Systems section. If you have sufficient free space, increase the value of the "Keep raw packet capture files for" setting. Future PCAP exports will include data from farther in the past.
