Previous Topic: TroubleshootingNext Topic: CA TIM is Not Configured to Use Napatech
Capture Card Clock Differs from System Clock
Symptom:
I see the following message on the System Status page, in the Capture Card Physical Port Status section:
"Capture card clock differs from system clock by N seconds."
Solution:
The capture card has an independent clock that stamps the time of incoming packets. In normal operation, this clock is synchronized with the Multi-Port Monitor system clock. The error message appears when there is a discrepancy between the Multi-Port Monitor system clock and the clock on the capture card. The discrepancy can occur when, for example, someone manually changes the time of the system clock.
Synchronize the clocks using the following methods:
