Previous Topic: Install the CA TIM SoftwareNext Topic: Create SNMP Traps
Set Global Preferences
You can configure global settings that affect the way data is automatically collected, stored, and forwarded, such as the following settings:
In most cases, the default settings are appropriate. However, you can change the settings to ensure the optimal functioning of your system.
  1. Click Administration, Application Settings in the web interface. The Application Settings page opens.
  2. Complete the following fields:
  3. Click Save. The Application Settings page is refreshed with your changes.
  4. Restart the nqmaintd process or the nqcapd process if necessary.
More information:
Packet Deduplication
Capture Card Physical Port Statistics
Stop or Restart a Process
What is Packet Slicing?
Purge Data from the Database
