Previous Topic: Architecture for CA Application Delivery Analysis SupportNext Topic: Overview of CA Application Delivery Analysis Data
Comparison with the CA Application Delivery Analysis Standard Monitor
The Multi-Port Monitor appliance and the CA Standard Monitor both aggregate and export IPv4-based TCP metrics to CA Application Delivery Analysis. The following table summarizes the most significant differences between the CA Application Delivery Analysis single-port monitor and Multi-Port Monitor when monitoring IPv4-based TCP traffic:
Feature
Standard Monitor
Multi-Port Monitor
Monitors multiple mirrored switch ports
Yes
Yes
Offers availability monitoring of servers, applications, and networks
Yes
Yes
Offers self-monitoring and alerting
Yes
Yes. The CA Application Delivery Analysis Inactive Monitoring Device incident is supported. SNMP traps provide additional alerting.
Monitors URLs
Yes
No
Supports investigations from the CA Application Delivery Analysis management console
Yes
Yes. Enhanced packet-capture investigations are supported.
Collects all CA Application Delivery Analysis metrics
Yes
Yes
Supports automatic configuration of servers, applications, and networks
Yes
Yes
Ignores duplicate packets (from a mirrored VLAN, for example)
Yes, after extra configuration.
Yes, automatically.
Provides performance data at 1-minute granularity
No
Yes
Filters and displays captured data for the specified host, server, or application
No
Yes
Receives packet digest data from a Cisco WAE device
Yes
Yes
Receives packet digest data from NI GigaStor
Yes
Yes
Supports CA Application Delivery Analysis on a 64-bit operating system
Yes
Yes. CA Application Delivery Analysis must be running on a 64-bit operating system to be compatible with Multi-Port Monitor.
