Previous Topic: Packet-Capture InvestigationsNext Topic: Comparison with the CA Application Delivery Analysis Standard Monitor
Architecture for CA Application Delivery Analysis Support
The following illustration depicts Multi-Port Monitor architecture and configuration to support CA Application Delivery Analysis. Multi-Port Monitor works within a typical CA Application Delivery Analysis distributed configuration, with network connectivity to the CA Application Delivery Analysis management console.
Depending on the configuration you purchased, one appliance can be connected to mirror ports on as many as eight separate switches. The appliance sends data from the monitored switches to the management console, where it is included in all CA Application Delivery Analysis reports.
Architecture for Multi-Port Monitor and ADA environment
