Previous Topic: What is Multi-Port Monitor?Next Topic: Packet-Capture Investigations
Support for CA Application Delivery Analysis
The Multi-Port Monitor appliance aggregates and exports IPv4-based TCP metrics to CA Application Delivery Analysis. The appliance collects more data, faster, than multiple Standard Monitors. The appliance is an alternative for enterprises that require high-volume monitoring with more flexibility and less overhead.
When monitoring IPv4-based traffic, the appliance stores packets to let you perform enhanced packet-capture investigations in CA Application Delivery Analysis. With a Standard Monitor, these investigations capture only the packets that are sent after the investigation is initiated. By contrast, the capture files that are stored on the appliance let you perform a forensic analysis of a performance issue.
When monitoring IPv4-based traffic with Multi-Port Monitor and the CA Application Delivery Analysis management console, you can perform the tasks below:
More information:
Integrating with CA Application Delivery Analysis
