Previous Topic: Assess and Recover XFS File System CorruptionNext Topic: Best Practices
Recreate the Vertica Metrics Database
Applies to CA6000 and CA6300 appliances
Recreate the Vertica metrics database to resolve database corruption. If the System Status page of the CA Multi-Port Monitor web interface indicates that Database Status is DOWN, and the database cannot be restarted, it is corrupted.
Database corruption typically occurs when the CA Multi-Port Monitor experiences a power outage or hardware hang.
Important: When you recreate the Vertica metrics database, all Session data is lost. Session data appears in the Analysis tab of the Multi-Port Monitor web interface.
Before you recreate the Vertica metrics database, verify:
Estimated time to recreate database: 5 minutes
  1. Open a command prompt.
  2. Stop all CA Multi-Port Monitor daemon processes:
    sudo /opt/NetQoS/scripts/stopprocs.sh
  3. Recreate the Vertica DB:
    sudo /opt/NetQoS/install/setupVertica.sh  --new
    sudo /opt/NetQoS/install/setupReplicateMySqlToVertica.sh
  4. Start all the CA Multi-Port Monitor daemon processes:
    sudo  /opt/NetQoS/scripts/startprocs.sh
  5. Use the System Status page of the CA Multi-Port Monitor web interface to verify the Database Status of the Metrics database is UP.
More information:
Assess and Recover SCSI Disk Corruption
