Both primary commands and line commands are allowed on this panel.
Column Name |
Description |
Jobname |
Displays the name of the job name for which thresholds are defined Generic notation is allowed by using wildcards _ and *. An underscore _ is a one-character placeholder. An asterisk (*) is a placeholder for one or more characters at the end of a name. Note: One generic entry * is required (you will see this entry in the first line of the panel). If no generic entry is found, APCYJLNA generates an error message on DD statement APCREP and discontinue execution. |
Elapsed |
Displays the elapsed column that contains the elapsed time threshold in minutes |
CPU Time |
Displays the CPU time threshold in minutes |
EXCPs |
Displays the EXCP threshold |
SRVU |
Displays the service units threshold Note: If more than one threshold entry applies to one job, PMA takes the entry with highest hit ratio. |
