When you choose option TH on the Parameters Menu, the List Open Alert Threshold Values panel is displayed. Use this panel to enter threshold values to be examined by PMA.
APCBPP08 --- PMA - List Open Alert Thresholds --------------------------------- COMMAND ===> SCROLL ===> HALF Search Mode : F ( F =First B =Best ) Commands : INS Insert CAN Cancel END Exit and Save Line Commands: I - Insert D - Delete C - Change LC Jobname Elapsed CPU Time EXCPs SRVU ------------------------------------------------------------------------------- ******************************* Bottom of data ********************************
You can enter separate threshold consumption values for session time, CPU time, and EXCPs per job or group of jobs. To discount a field, enter the maximum possible value.
Thresholds for each job or job group are represented by a detail line on the bottom half of the panel. This area of the panel can be scrolled.
