When you choose option X6 on the Parameters Menu, the List Job Libraries panel is displayed. Use this panel to enter job libraries to be examined by PMA.
APCBPP03 --- PMA Central Component - List Job Libraries ------ Row 1 to 2 of 2 COMMAND ===> SCROLL ===> HALF Commands : INS Insert CAN Cancel END Exit Line Commands: I - Insert D - Delete C - Change LC Dataset name ------------------------------------------------------------------------------- PROD.JCL.LIB1 PROD.JCL.LIB2 ******************************* Bottom of data ********************************
If you have not entered any job libraries, the insert panel is displayed and you are requested to enter the name of the job library to be examined.
The job libraries defined here are examined in batch to determine which application program is called in which job step.
