Administration of the Central Component › Parameter Administration › Defining Load Module Libraries › Panel Elements
Panel Elements
Both primary commands and line commands are allowed on this panel.
- To insert a new load library and define its size, use line command I or primary command INS and enter the data set name of the load library.
- To delete a load library definition in the list, place the cursor in the LC column next to the specific data set name and enter line command D. Once deleted, the load library is no longer searched for program modifications.
- To change an existing detail line, place the cursor in the LC column next to the specific job name and enter line command C. You can change the load library name only if it does not already exist in the list.
