Previous Topic: Panel ElementsNext Topic: Panel Elements
Excluding Jobs ( CA MAT Scope)
When option 3 on the Scope of Workload window is selected, the Job Exclusion panel is displayed for the exclusion of jobs from the measurement tool in use.
APCBP043 --- PMA - Job Exclusion (CA MAT Scope) -------------- Row 1 to 1 of 1 COMMAND ===> SCROLL ===> HALF Commands : I -Insert Line Commands: I -Insert D -Delete C -Change The following Jobs/Jobsteps will GENERALLY NOT be measured by CA MAT LC Jobname Stepname Procstep Description ------------------------------------------------------------------------------- ABC* APPLICATION WILL BE REPLACED SOON ******************************* Bottom of data ********************************
Use the Job Exclusion panel to define the following items:
