Previous Topic: General ParametersNext Topic: Using the Window
Accessing the Scope of Workload Window
When option X2 on the Parameters Menu is chosen, the Scope of Workload window is opened, as shown following.
APCXPP00 --- PMA --- Parameters Menu -------------------------------------- Enter an Option ===> TSO User U1 Print Job JCL Global Parameters G1 Measurement DS processing Global Online Parms G2 CICS and IMS Central Component X1 General Central Component Parameters X2 Scope of Work +---------------------------------------+ | APCBP004 Scope of Workload | | | | 1 - Job in/exclusion for PMA | | 2 - PGM in/exclusion for PMA | | 3 - Job exclusion for CA MAT | | 4 - PGM exclusion for CA MAT | | | Thresholds +---------------------------------------+ TX Performance Index Alert Thresholds TM Minimum Consumption Thresholds TH Open Alert Thresholds PMA SERVER S1 General PMA SERVER Parameters CICS Feature C1 General CICS Feature Parameters C2 System Control C3 CICS Load Module Libraries C4 CICS SMF Scope Definitions C5 CICS SMF Aggregation Control IMS Feature I1 General IMS Feature Parameters I2 System Control I3 IMS Load Module Libraries I4 IMS INFO Scope Definitions I5 IMS INFO Aggregation Control
On the Scope of Workload window you can select an option to include or exclude jobs and programs. For a detailed description regarding the scope of work concept, see section Reducing the Scope of Work.
