When option 2 on the Scope of Workload window is selected, the PGM In/Exclusion List panel is displayed for the inclusion or exclusion of programs when defining the Scope of work.
APCXP042 PMA - PGM In/Exclusion List (PMA Scope)----------- Row 1 to 14 of 14 COMMAND ===> SCROLL ===> HALF Commands : I -Insert Line Commands: I -Insert D -Delete C -Change If EXCLUDED the following programs are NOT in the PMA workload scope If INCLUDED ONLY the following programs are in the PMA workload scope LC PGM name IN/EXCLUDED Description ------------------------------------------------------------------------------- ADRMAIN EXCLUDED BMC UNLOAD UTILITY ADUMAIN EXCLUDED BMC UNLOAD UTILITY ADUUMAIN EXCLUDED BMC UNLOAD UTILITY APC* EXCLUDED APC PRODUCT PROGRAMS BTCUTILB EXCLUDED SE PGM TO CALL DSNUTILB - EXCLUDED DFH* EXCLUDED STANDARD PROGRAM EXCLUDED DSNUTILB EXCLUDED STANDARD PROGRAM EXCLUDED ICEGENER EXCLUDED STANDARD PROGRAM EXCLUDED IDCAMS EXCLUDED STANDARD PROGRAM EXCLUDED IEB* EXCLUDED STANDARD PROGRAM EXCLUDED IEFBR14 EXCLUDED STANDARD PROGRAM EXCLUDED IEWL EXCLUDED STANDARD PROGRAM EXCLUDED SORT EXCLUDED STANDARD PROGRAM EXCLUDED SYSSORT EXCLUDED STANDARD PROGRAM EXCLUDED ******************************* Bottom of data ********************************
Use the PGM In/Exclusion List panel to define the scope level 2 for programs. All definitions must be either inclusions or exclusions.
Exclusions are recommended when defining the scope of work for program names.
