After you install Job Management Manager (the manager) on OpenVMS, perform the following procedures:
Start the manager on the nodes on which you installed it (if they are not started as part of the installation procedure).
This section contains the following topics:
Starting Job Management Manager
Editing the System Startup and Shutdown Files
Starting Job Management Manager on an OpenVMS Cluster
Shutting Down Job Management Manager
Checking SYSGEN Parameters Minimum Quotas
Checking the Minimum Privileges for Job Management Manager
Entering a Proxy for Each User Account
Setting Up a Proxy in AUTHORIZE database
