Previous Topic: Access Restriction to the SYSTEM Account
Next Topic: Process Priority
Custom Startup Files
The product startup can be customized according to instructions delivered within the template file NSCHED$COM:UJM$MANAGER$STARTUP_LOCAL.TEMPLATE.
However, such customizations affect how the manager runs and what it does. Before attempting any customization of the Job Management Manager startup procedure, read the referencing sections. For more information about the system logical names, see the following:
The following files contain several logical name definitions that you can modify to customize Job Management Manager for your particular system or cluster.
Change the values of the logical names as needed, following instructions within the comments in the custom startup files. For a list of these logical names, see the Job Management Manager Logical Names. If either of these files are not present in NSCHED$COM, after upgrading a noncustomized version of Job Management Manager, or after performing a new installation, you can copy the template file NSCHED$COM:UJM$MANAGER$STARTUP_LOCAL.TEMPLATE as file names listed, then customize as required.
Note: The upgrade installation procedure processes any relevant logical name found on the system and automatically rebuilds the custom startup files accordingly.
