If you chose the option to shut down the manager, the installation procedure has already shut down the manager.
If you did not, you can use one of the following methods to shut down the manager after the installation procedure is complete:
$ @SYS$STARTUP:UJM$MANAGER$SHUTDOWN.COM
or
$ @SYS$STARTUP:CAPOLY$SHUTDOWN.COM
$ SUBMIT/USER=SYSTEM SYS$SHUTDOWN:UJM$MANAGER$SHUTDOWN.COM
or
