If you chose the option to start or restart the manager, the installation procedure has already started the manager.
If you did not, you can use one of the following methods to start or restart the manager after the installation procedure is complete:
$ @SYS$STARTUP:UJM$MANAGER$STARTUP.COM
$ SUBMIT/USER=SYSTEM SYS$STARTUP:UJM$MANAGER$STARTUP.COM
$ @SYS$STARTUP:CAPOLY$STARTUP.COM
