Previous Topic: Step 6. Run the Installation Verification Procedure (optional)
Next Topic: Step 8. Purge Previous Version Files
Step 7. Start the Application After Installation
During the installation process you can choose to start or not start Job Manager after the installation completes.
Note: If you already chose to run the Installation Verification Procedure (IVP), no prompt occurs for the startup option, as the IVP requires the Job Management Manager to run.
If this is the first time you are installing the application on your system, you are asked if you want the software to start right after the installation. Select one of the following responses:
YES
The application is started after the installation.
NO
The application is not started after the installation.
