Previous Topic: Step 5. View and Accept the License Agreement
Next Topic: Step 7. Start the Application After Installation
Step 6. Run the Installation Verification Procedure (optional)
After the installation, the Installation Verification Procedure (IVP) checks to ensure that the installation was successful. It starts the application and performs function tests. We recommend that you run the IVP, so the installation gives you the opportunity by asking if you want to run it after completing the installation. Select one of the following responses:
YES
The IVP runs after the installation completes and automatically starts the product.
NO
The IVP does not run after the installation completes and the startup prompts.
Note: If you choose not to run the IVP during the installation, you can run it at any time after the installation completes by entering the following command:
$ @SYS$TEST:UJM$MANAGER$IVP.COM
