Previous Topic: Step 7. Start the Application After Installation
Next Topic: Step 9. Choose Whether to Install the DECwindows Interface (Optinal)
Step 8. Purge Previous Version Files
You can purge files from previous versions of the product that are superseded by this installation. We recommend that you purge your old files; however, if you need to keep files from a previous version you can choose to not purge your files. The installation asks if you want to purge files replaced by this installation. Select one of the following responses:
YES
The files related to earlier versions of the product are purged after the installation completes.
NO
The files related to earlier versions of the product are left on the system after the installation completes.
