You can convert CA Ideal application programs and panels in Production status from VLS members to z/OS load modules or to VSE phases. If a program is converted to load module format, load modules are created for the executable object and the symbol table.
Note: For the sake of convenience, load module in this guide refers to both load modules and phases.
For each program, separate load modules are created for the reentrant and non‑reentrant data, respectively, and for the symbol table. If a panel is converted to load module format, a single load module is created. The panel load module contains the panel member from the panel library, comprising both reentrant and non‑reentrant data.
Even when VLS members are converted to load modules, the original object members are retained and can be used again. MODULE entity occurrences in the Datadictionary record which programs or panels were converted to load modules and which were deleted as load modules. If an entity accessed from CA Ideal is not recorded as a load module, CA Ideal retrieves it from the VLS library.
