Previous Topic: Parameter CreationNext Topic: Create and Use Scripts to Modify Text Files
Replacing SXP Parameters in UNICODE Files
To replace SXP parameters in UNICODE files external to the SXP package, you must specify the UNICODE file names in the #ReplaceParamsUNICODE# section of the files.sxp archive file.
To edit the files.sxp archive file, double-click the files.sxp icon in the Packager GUI. The files.sxp editor opens where you can select the #ReplaceParamsUNICODE# section from the Section drop-down list.
