You can write script files that contain instructions for modifying text files. The Packager uses the scripts to adapt ASCII files for specific target computers.
In your scripts, you can use parameters as variables for values specific to a target computer.
To write a script for use with a product, you must use the Packager scripting language. You will find the description of the Packager scripting language in the Software Management Packager Help.
