Previous Topic: Specify Enhancements to the Automatic MethodNext Topic: Dependency Specification
Edit Archive Files
To open and edit an archive file, double-click the icon of the archive file in the Product Archive window, or right-click the icon and select Edit Archive Files from the context menu.
When you double-click the icon of an archive file in the Product Archive window, an archive file editor window appears displaying the contents of the file.
You can select the section you want to edit from the Section list box, if available. The current parameters are listed under Contents. For some archive files you must add or edit the content directly in the input area. When the editor window is open, the Packager main menu is adapted and provides editing functions for the archive file on the Edit menu and functions for saving and closing the archive file on the File menu.
A short syntax description of the section entries can be found in the footer of the editor window. If you want more detailed information about the structure and syntax of the archive file, open the Packager's online help and click the file name in the Archive Files Overview help topic.
If you double-click a CMP archive file (filesn.cmp or ufilesn.cmp), the built-in CMP Editor launches and provides all functions you need to modify the compressed files. To edit the CMP archive files, use the CMP Editor only, because this ensures the correct handling of special characters independent of the used codepage.
The majority of SXP files are created automatically and assigned data by the reference installation. Therefore, it is not necessary to edit all SXP archive files and all sections of the SXP archive files.
The following topics provide basic descriptions for manual entries you can generate.
