Previous Topic: Install the SoftwareNext Topic: List of File System Changes
Use the Software
After you have completed the reference installation, close all windows except the Packager window, and click Continue on the Installing Software dialog. The Using the Software dialog appears.
You are prompted to start and close the software programs you have just installed. This action is necessary because many applications create their entries in the registry only when they are started for the first time. If these registry entries are not recorded now, with the reference installation, you will not be able to delete them later when the product is uninstalled on the target computer.
If you do not want the changes made by the programs at initial startup to be recorded, you do not need to start and close these programs.
Before you click Continue on the Using the Software dialog, you can still make changes to the product you are installing. For example, you can add or remove files; or insert parameters in product-specific files, as described in the topic Specify Enhancements to the Automatic Method.
When you click Continue, the Analyzing System dialog appears, and the Packager begins comparing the last saved system state before the reference installation with the current system state after the installation. The differences between these two states comprise the data from which the SXP archive files are created.
