Previous Topic: Create Product VersionNext Topic: Use the Software
Install the Software
After you click Continue on the Create Product Version dialog, the Installing Software dialog appears and the reference installation begins. All changes made to the reference system, beginning with those made from the Installing Software dialog to those made from the Using the Software dialog, are incorporated in the archive product.
During the reference installation, you may be asked to log off and on again, or to restart the computer. In such situations, the Packager for Windows ensures that, when the system restarts, it resumes the packaging process from the exact point at which it was interrupted.
Important! If you are going to package an MSI product you must ensure that all desired features of the MSI product are completely installed on the Packaging Computer before packaging the MSI product. No feature must be installed with the Installed on First Use option. This complete installation is necessary, as during the default installation of an MSI product, for example, Microsoft Office, some of its features are only published and not installed, and therefore cannot be packaged in the SXP product. To install the desired features completely, choose the MSI Custom Installation and, in the features tree, select the option to install all features on the local drive.
