Using the Packager for Windows › How to Package Products Using the Automatic Method › Create Product Version
When you create a product version (with or without dependencies) or a delta version, follow these steps:
- Install predecessor (if creating a delta version)
- Install the software
- Use the software
- Make a list of file system changes (Custom Mode)
- Specify install and delete options for files and directories (Custom Mode)
- Specify enhancements to the automatic method (optional)
Important! Use this process to create a delta version only if you know exactly which files need to be updated or added in order for the newer version of the product to run.
