Previous Topic: Root DirectoriesNext Topic: Create a Combined or Delta Product or a Delta Version
Options for Deleting Directories
Directory delete options are assigned to each directory. Each delete option is represented by a different symbol. You can individually change the delete option for each directory.
You must uncheck the delete folder symbol (directory is not deleted) for each multi-use directory and all of its higher-level directories. A multi-use directory is a directory used by two or more applications.
