Previous Topic: Restoring Default SettingsNext Topic: Disk Space Considerations
Backup Files
The Backup files tab lets you select paths and files to protect by creating backups. The Backup tab is not displayed when the reference system reset phase is disabled (see Reference System Reset).
The first time the Packager is used, the drives, paths, and files you specify on the Backup files tab are backed up automatically, so that they can later be restored.
If you select the Recursively option, all subdirectories are also backed up in the archive.
If you make changes on this tab and click Apply or OK, the changes are automatically incorporated in the backup archive, and the Update Reference System dialog automatically appears.
