Previous Topic: Partial Changes for ASCII FilesNext Topic: Backup Files
Restoring Default Settings
You can use the Defaults tab to reset all the reference system settings to their factory settings.
When the Packager is installed, it sets default values for all tabs on the Configure Reference System dialog. However, when you create a product or configure the reference system, you can change one or more of the values on those tabs.
Using the Defaults tab of the Configure Reference System dialog, you can restore these values to their factory settings. Note that these default settings apply to all products you later create.
