Previous Topic: Checking the Status of the HostNext Topic: DSM Properties - Remote Control Dialog
Host Properties
Host properties include settings for security, communications protocol, connection type, and so on. Configuration of the host computer is done using the DSM Properties - Remote Control dialog.
There are several ways to view host properties:
The DSM Properties - Remote Control dialog opens. This dialog contains several tabs that you can select for specific information about the host.
