Previous Topic: Changing the Text of the Viewer’s DialogsNext Topic: Change the Text of the Replayer’s Dialogs
Translate the EGC-based Viewer
The EGC-based viewer obtains its resources from a number of places:
You must configure EGC to use the new gui_rcview.dll file. To do this, create the following registry entries (assuming the Swedish locale, SE):
[HKEY_LOCAL_MACHINE\SOFTWARE\ComputerAssociates\EGC3.0N\Locale\SE]
"HelpFile"="C:\\Program Files\\CA\\SC\\EGC\\egc30enu.chm"
"ResourceDLL"="C:\\Program Files\\CA\\SC\\EGC\\egc30Nres.enu"
[HKEY_LOCAL_MACHINE\SOFTWARE\ComputerAssociates\EGC3.0N\Plugins\ITRMRC_DSMVIEW\Locale\SE]
"HelpFile"="C:\\Program Files\\CA\\DSM\\help\\gui_rcview_help_enu.chm"
"MessageHelpFile"="C:\\Program Files\\CA\\DSM\\help\\gui_rcview_msg_enu.chm"
"ResourceDLL"="C:\\Program Files\\CA\\DSM\\bin\\gui_rcview_se.dll"
A simple way of doing this is to export the existing English entries to a text file, edit them using Notepad, and then import back to the registry.
This example assumes that Remote Control is installed in the default location on the C drive. It still uses the English help files, since you cannot localize these.
