Previous Topic: Configure Host Remote Control PermissionsNext Topic: Control the Visibility of Viewer and Host Properties
Customizing Remote Control
You can customize the locally managed properties and security prior to installation to ensure optimum settings for your environment. Typically, customization is usually only necessary in a stand-alone environment. The settings that control the properties, security, and policy are stored in XML files (see Extract XML Files) that you can edit during an MSI Administrative install.
Note: This chapter is for advanced users of Remote Control. Entering incorrect information in any of the customization procedures may result in the product not working properly.
This section contains the following topics:
Control the Ability to View and Manage Properties
Control Default Values
Localizing the Remote Control Dialogs
