The default.ini parameter sections have the following structure:
[parametername] Type={ Text | Pwd | IP | Num | BootImage | OSImage | Mac | MapList | MapListExt | TextList | TextListExt }
The remaining entries of a parameter definition section and their ranges depend on the parameter type (Type=).
Provides any simple text string. The length of the string can be limited by the MaxLength attribute. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the strings to be assigned |
1 to 255 characters |
Comment |
Comment on the parameter |
any string |
Trans |
Drives the inheritance of parameter settings |
{yes|no} |
UpdateDefault |
Overwrites the default value when updating the image |
{yes|no} |
Provides an encoded password. The password can be limited to MaxLength characters. A password is always related to a user ID. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the password to be assigned |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies an IP address of the format a.b.c.d where each a...d represents an integer value between 0 and 255. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the IP address |
17 characters |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies a numeric value. The range of the value is given by the attributes MaxValue, which specifies the maximum, and MinValue, which specifies the minimum. The value of MinValue must be less than or equal to the value of MaxValue. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxValue |
Maximum of the value assigned |
-2147483648 to 2147483647 |
MinValue |
Minimum of the value assigned |
-2147483648 to 2147483647 and MinValue <= MaxValue |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies the name of a boot image. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the boot image name |
1 to 8 characters |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies the name of an operating system image. The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of the operating system image name |
1 to 10 characters |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies a MAC address of the format ab.cd.ef.gh.ij.kl where each a...l represents a hexadecimal digit (0-9, a-f). The following parameter attributes are valid for this parameter type:
Attribute |
Meaning |
Range |
MaxLength |
12 characters |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Specifies a list of item=<string1> <string2>. String2 is shown in the editor only, when string1 has been assigned a value.
The parameter editor can extend parameters of type MapListExt, but not of type MapList.
When assigning a value to a parameter, it can only be a string that is appearing in the list.
The following parameter attributes are valid for these parameter types:
Attribute |
Meaning |
Range |
MaxLength |
Maximum length of a list entry |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Item |
Specifies a list item. This attribute can occur more than once. |
"string1" "string2" |
TextListExt specifies a list of item=<string>; that is, it is the same as a TextList parameter, but the list can be extended with the parameter editor later on.
Attribute |
Meaning |
Range |
MaxLength |
Comment |
any string |
Trans |
{yes|no} |
UpdateDefault |
{yes|no} |
Item |
any string |
The RegisterOSImage command provides an option to overwrite the default values of the parameters in the database. For the overwrite operation to be successful, you must set the UpdateDefault attribute of the parameter to Yes; Otherwise, the default value are not overwritten. The following RegisterOS command overwrites the default values:
RegisterOSImage -i <image_name> -s <manager> -e [-b]
