The process of prepare (sysprep Step4) modifies the OS installation on the model computer such that it cannot reboot into the operating system anymore. You can back up the model computer so that you can restore the same and boot into the operating system after you have captured the image.
To backup an image, you must run an OSIM backup job that captures the OS image using the specified imaging tool.
To create OSIM install jobs to back up an image:
Parameter |
Description |
OSImage |
Specify "getimg" or "getwepos" depending on the support OS type. |
BootSpecial |
Specify "WinPE2.2" or "WinPE3.2" |
ImagexImage |
Specify the name of the image file to create. |
CreateImage |
Specify "backupImageX" or "backupGhost" |
BackupPolicy |
Specify the backup policy for the job. |
The following events occur:
Note: The success of directory creation depends on the BackupPolicy that you have set. If the BackupPolicy is set to write images and wrap around, getimage.cmd overwrites the oldest image when the defined number of images already exists. If the BackupPolicy is set to write images and not wrap around, getimage.cmd aborts with an error message that the directory name already exists.
\\<OSIM-image store>\<imagename>\<imagename>\images\<computername>\
<$ImageXImage$n>\<$ImageXImage$n>.wim
The following screenshot shows the location of the new image:
Note: If the C: partition does not exist on the model computer, the getimage.cmd command terminates after writing to the error to the log file.
For Ghost32, the directory contains the ghost.exe file and the file <$imageXImage$>.gho will be created by getimage.cmd.
