Drives the parameters settings when an operating system image is assigned to a target. When an operating system image has a predecessor image (Current or Scheduled configuration) for the target in question, a parameter of the new image also occurs in the old image, and both parameters are of the same type, then the parameter of the new image inherits the parameter setting from the predecessor configuration provided that the Trans attribute of the parameter at the new image has been set to yes. In any other case, the parameter of the new image is set to its default, if there is any, or it remains unset.
Example: Add OSIM OS Image Parameters
