The Refine/Define Schema Mapping wizard page lets you define a new schema map or refine the specified schema. Schema of the directory defines the names and types of the attributes. Schema mapping translates a directory objects attributes, or properties, as defined by that directory schema to a common schema used by other DSM-based applications.
Note: A number of predefined schema maps are provided for the most popular schemata, including hard-coded maps for the WinNT and UnixL providers.
The appropriate mapping table appears, displaying the names and types of the attributes in the specified directory schema.
The Attribute Mapping dialog appears.
The Attribute Mapping dialog closes, returning you to the wizard page.
See Schema Mapping for more information on schema.
