Previous Topic: Computer Properties: Computer TabNext Topic: Specify Directory Server Details
How to Configure and Authenticate External Directories
As a desktop support analyst, you use external directories for authentication. Using the external directories in the DSM Explorer, you can do the following tasks:
To authenticate using external directories, perform the following steps:
Perform the following steps:
  1. Add a Directory to the Repository
  2. (Optional) Import a Certificate (LDAPS only)
  3. Verify the Configured Directory
  4. Authenticate the Configured Directory
  5. Verify the Directory Authentication
Supported External Directories
CA ITCM supports the following directories:
See Compatibility Matrix for an updated list of the supported directory integration services.
Verify the Prerequisites
To authenticate using an external directory, verify the following prerequisites:
To authenticate users and authorize users by mapping security profiles to entities in the directory, add the external directory to the repository first.
  1. Navigate to the Control Panel, Directory Integration, Add Directory to access the Add Directory Wizard, Click Next.
    The Introduction/Directory Name page appears.
  2. Specify the directory name to identify the directory when connecting to Active Directory in Directory Name.
  3. Select the type of directory using one of the Directory Type options. The following options are available:
    Default: Active Directory.
  4. Click Next to go to the Server Details page.
