Previous Topic: Update Directory: Schema TabNext Topic: DSM Attribute Names
Understand the Schema Mapping Attributes
A schema map is a mapping of the attribute names associated with data objects (such as users, computers, and groups) in an external directory to those attribute names used by corresponding DSM objects. The fixed and standard set of DSM attribute names is used for querying directories and for formulating complex queries and reports.
Three predefined, common schema mappings are provided in CA ITCM. You also have the option to create your own custom schema based on the predefined schema set.
