oftware delivery allows the polite shutdown of a target computer. The polite shutdown policies control the politeness of an initiated shutdown.
To configure the polite shutdown policies
A list of all the policies in the Shutdown policy group appears.
Specifies that the Shutdown routine forces programs to shut down if the value is set to True.
Default: False
Specifies the number of times the shutdown prompt can be postponed.
Default: 5
Specifies that a requested shutdown is not initiated automatically if the value is set to True. Instead, a message appears and prompts the user to save all the work. The message does not include a timer and waits for the user’s response. The shutdown initiates only when the user closes the message. The Shutdown routine uses this policy.
Default: False
Specifies the timeout period in seconds for the Shutdown dialog. If the timeout period is empty (not set), the initial timeout is 5 minutes, and every consecutive postponement is 5 minutes in duration. If the timeout period is set to some value, both the initial timeout and the consecutive postponements use the specified value.
Default: 300
The polite shutdown policies are configured.
