Previous Topic: Define a Time RangeNext Topic: Configure the Polite Shutdown Policies
Specify the Boot Level after Execution Property
You can set the Boot Level after execution property to the Shutdown machine after last job option while performing the following tasks, so as to reflect the property in the job options of an SD job:
The following example procedure explains how you can specify this option for a new software policy:
Example: Specify the Shutdown Job Option for a New Software Policy
You can set the Boot Level after execution property to the Shutdown machine after last job option while creating a software policy.
To specify the shutdown job option for a new software policy
  1. Navigate to the Policies, Software Based folder.
    A list of all the software policies appears.
  2. Right-click the Software Based folder, and select New Software Policy from the context menu.
    The Create Software Policy wizard opens.
  3. Follow the instructions in the wizard to create a software policy.
  4. Select the Open the advanced Software Policy settings dialog when the Finish button is pressed option on the Finish screen of the wizard.
  5. Click Finish.
    The New Software Policy dialog opens.
  6. Click the Jobs tab, and then click Procedure Options.
    All the procedure options appear.
  7. Select the Shutdown machine after last job option from the Boot level after execution drop-down list.
  8. Click OK.
    The software policy shuts down the computer when execution of the last SD job is completed.
More information:
How to Use the Shutdown Functionality
