To use the shutdown functionality, the first step is to define a value for the Shutdown Behavior configuration policy. This value controls the overall shutdown behavior of the computer. After you define the value for the policy, perform the appropriate step based on the defined value:
Note: The value "0" signifies that shutdown must not be performed.
The shutdown functionality is closely linked to the process of pushing an SD job to a target computer. The configured Shutdown Behavior policy is not activated until an SD job is pushed to the computer. When you push an SD job to the computer, the job evaluates the value assigned to the Shutdown Behavior policy. It then takes the appropriate action—shut down or do not shut down—after completion of the last SD job. If you do not push an SD job, the value assigned to the policy parameter does not perform any action.
Note: Shutdown of a domain manager is not allowed, that is, you cannot shut down a domain manager either by using the job option or by using the power management calendar setting.
