Previous Topic: Backwards Compatibility Support Policy GroupNext Topic: Shared Policy Group
Communication Policy Group
The Communication policy group governs CA-SD communication protocols for Unicenter Software Delivery extended and legacy agents.
The Communication policy group contains the following policies:
Backwards compatibility support: Agent connect port
Specifies the port for the server to listen for legacy Unicenter Software Delivery agent connection requests.
Default: 4721
Backwards compatibility support: FileTransferBlockSize
Specifies the size of file transfer blocks in kilobytes (KB). If you are running on fast networks, increasing the size generally improves performance.
Limits: 4–32
Default: 4
Backwards compatibility support: Max Connections
Indicates the maximum number of network connections allowed to and from this computer.
Default: 550
Backwards compatibility support: Max Peers
Indicates the maximum number of allowed network application peers for this computer.
Default: 200
Backwards compatibility support: SysRcvTimeout
Specifies the common system receive timeout interval in seconds.
Note: If -1 is specified, the timeout is indefinite.
Default: -1
Backwards compatibility support: Trigger port
Specifies the port number of the trigger process (TRIGGER).
Default: 4725
Backwards compatibility support: WaitCCTimeout
Specifies the wait timeout interval in seconds for connection confirmations.
Limits: 1–1000
Default: 120
Backwards compatibility support: WaitCRTimeout
Specifies the wait timeout interval in seconds for connection requests.
Limits: 1–1000
Default: 120
