Backwards Compatibility Support Policy Group
The Backwards Compatibility Support policy group lets you view or edit Agent Bridge support policies for Unicenter Software Delivery legacy and extended agents. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
This policy group contains the following policy group folder:
Communication
The Backwards Compatibility Support policy group also contains the following policies:
Enables Agent Bridge scalability server support for Unicenter Software Delivery legacy agents and Windows CE agents, if set to True. If False, this policy disables server support for Unicenter Software Delivery legacy and extended agents.
Note: Enabling SD Agent Bridge support does not mean that the AM Agent Bridge support is automatically enabled. For more information, see the Enable Agent Bridge configuration policy in Asset Management Policy Group.
Default: False
Enables support for a new writable share, SDOUTPUT, under SDLIBRARY$ on the server, if set to True. If False, this policy disables support for the new writable share, SDOUTPUT. This server policy should be set to True if legacy agents prior to Unicenter Software Delivery 4.0 are connected to the server and using the NOS connection method for software delivery library access. This policy allows job output files to be written directly to the SDOUTPUT library share.
Default: False
