File Transfer Server Policy Group
The File Transfer Server policy group lets you view or edit the existing computer policy properties for the File Transfer Server component (cfftplugin). You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the bandwidth limitation of each file transfer connection in megabits or kilobits. This policy applies to the side that is sending the data. Valid values are as follows:
Default: Unlimited
