Event Logging Policy Group
The Event Logging policy group contains the following event log policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the file name for event logs. If no file extension is specified, “.log” is appended automatically. Note that rotated log files have file extension ".001," ".002," and so on.
Note: The Events.log file is by default created in c:\Program Files\CA\DSM\logs. You can change the default path; however, the log file is then created only after restarting the Common Application Framework (CAF), but not immediately.
Default: Events.log
Specifies the event message file defined to the Init() method. If none is provided, cfEventMsg.txt is used by default.
Default: cfEventMsg.txt
Specifies the event source defined to the Init() method. If none is provided, DSM is used by default.
Default: DSM
Indicates whether DSM log events are compatible with earlier versions of Unicenter Software Delivery and Unicenter Asset Management.
Default: False
Specifies the UNIX syslog facility. Valid values are as follows:
Default: -1
Specifies the event log destination. You can specify multiple destinations by adding flags together. Valid values are as follows:
Default: 1
Example: To specify the OS and CCS event log destinations, specify a value of 6.
Specifies the maximum size of event logs in kilobytes.
Default: 100
Specifies the number of generations for file log rotation. A value of 0 indicates that no rotation is to take place.
Default: 10
