Audit Messages Policy Group
The Audit Messages policy group lets you view or edit the policy for ENC audit messages. Each message can be enabled or disabled. By default, all messages are enabled.
You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog. There is a parameter for each message whose value is either True (enabled) or False (disabled).
There are too many messages to list in the online help, but each message is described in the following way:
Note that all messages are usually enabled so the decision to actually generate the message depends on the category to which it belongs. Messages are generated if both the category and the message are enabled.
Example
Name: (Client) Client connected
Category: client
Description: Audit event: The ENC Client has connected to ENC Gateway Server.
Value: enabled
